При переходе по ссылке http://pomnim.motocitizen.info/ выдает только непонятный скрипт.
http://gyazo.com/aac0d43ce2c7852158015cfa407f8053
<?php /** * Front to the WordPress application. This file doesn't do anything, but loads * wp-blog-header.php which does and tells WordPress to load the theme. * * @package WordPress */ /** * Tells WordPress to load the WordPress theme and output it. * * @var bool */ define('WP_USE_THEMES', true); /** Loads the WordPress Environment and Template */ require( dirname( __FILE__ ) . '/wp-blog-header.php' );
